    Dismiss Notice
    Dismiss Notice
Wood basement wall question
Discussion in 'Residential Foundation Codes' started by Down under, Jan 27, 2019.
  1. Down under
    Down under Registered User
    Jan 27, 2019
    4
    0
    Hi purchased a bilevel house wood wall basement 5 foot below grade at front sloped to a walkout at back. Basement floor has in ground pex run and is insulated, no boiler yet. I found a 2 inch gap around the base of the floor and the wood wall, and footing .Can see gravel . The walls are level no shifting or cracks in drywall on upper level.it appears to have been built this way . First time i have come across so any explanation ,information or recommendations are appreciated.
    Thanks in advance
  2. Flexo
    Flexo Registered User
    Jan 28, 2018
    22
    3
    Search "permanent wood foundation" on the net. You will learn a lot. Treated wood foundation systems are one of the prescriptive methods detailed in the International residential code.
  3. cda
    cda Sawhorse
    Oct 19, 2009
    15,318
    919
    What is the footing made of??
    Poured concrete??? if so does it appear to be level the entire run?
    How old of house?
  4. Down under
    Jan 27, 2019
    4
    0
    I'll check for floor level yes poured .none of the wood or drywall in rooms has water stains or has been replaced. .. House is 20 years old
  5. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,743
    242
    Basement floor is slab on grade?
    Can you see the top half of wood wall? What is it finished with?
    Does exterior grade slope away from house?
    Are you in a frost zone?
    Adjacent to any water sources?
  6. Down under
    Jan 27, 2019
    4
    0
    Hi house is about 5 feet below grade at front slopes to walkout at back. Southern Alberta, so some frosting ground, but I doubt if it's much . No water sources close by. Walls are pressure treated wood . Im guessing it was built with intent to put in French drain system .
  7. cda
    cda Sawhorse
    Oct 19, 2009
    15,318
    919
    If you are or know someone computer/ photo smart, i am not
    You can take a few pictures,
    Turn them into a link
    And post the link here
    Might help see what is going on
  8. Down under
    Jan 27, 2019
    4
    0
    I'm away from the house until next Friday..Will post pic on weekend..
Share This Page
