    Dismiss Notice
    Dismiss Notice
Won Door and pocket receiver for won door.
Discussion in 'Door & Hardware forum *Sponsored by Allegion' started by Builder Bob, Dec 12, 2018.
  1. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    1,964
    255
    Currently reviewing a won door being installed as a three hour opening protective between wings of a school - Fire wall cut buildings in half for area limitations. The termination wall has a recessed pocket receiver that cuts the depth of the 8 inch blow down to 3 5/8" thickness if filled solid with grout - Calculated fire resistance of the IBC indicates that this is only good for 1 3/4 hr. rating at this point. The Evaluation report from ICC indicates that the door and related materials have been tested for the time periods listed - The fire door (won door) is slightly offset and terminates into a 8 inch block wall that will carry a 3 hour rating UL U904.
    Am I really just overthinking this?
    Builder Bob
  2. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Good question!!!
    1. Does won door give any installation guidance, at that point??
    2. Does the door it self provide thevrating??? At that point
  3. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Builder Bob likes this.
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    729
    Fatten out the masonry on the backside? If it doesn't terminate to the face of the assembly with a 3hr joint, I think you are absolutely on the right track to ensure that the rating is maintained at the "penetration"...
  5. Builder Bob
    Oct 17, 2009
    1,964
    255
    Thanks CDA - I couldn't find the information you provided initially..... The answer is in section 2.04(D).
  6. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    I have not won-Doored in years
    And never thought about the rating where it stops
    Anyway have fun
Share This Page
