    Dismiss Notice
    Dismiss Notice
Service Panel not quite ready?
Discussion in 'Electrical Codes' started by jar546, Feb 5, 2019.
  1. jar546
    jar546 *****istrator
    6,047
    316
    This is a service panel for a single family residence. The 2" conduit leaves this combo enclosure to feed a sub-panel inside the residence.
    How many violations do you see in this photo? Solely based on what you see.
  2. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,657
    288
    Could use some Red, White and Green tape!
    jar546 likes this.
  3. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,601
    142
    white or gray tape on the grounded conductor NEC 200.6
  4. jar546
    6,047
    316
    Red and white, yes. Green, hmmmm not quite.
  5. jar546
    6,047
    316
    There is more than marking the neutral wrong.
  6. LCBob
    LCBob Registered User
    Dec 22, 2018
    6
    2
    Maybe the absence of a grounding electrode conductor?
    jar546 likes this.
  7. jar546
    6,047
    316
    Bingo
  8. LCBob
    Dec 22, 2018
    6
    2
    I can see the intersystem bond cover and the ground rod clamp laying in the bottom of the panel, and I can hear the electrician saying "You weren't supposed to be here 'til this afternoon."
  9. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,070
    750
    Why is the green wire not the GEC?...Got it...missed that they were feeders....But then the GEC could be upstream somewhere that we can't see ...Like at the drip loop.....no?
    E3607.2 Location of grounding electrode conductor connection.
    The grounding electrode conductor shall be connected
    to the grounded service conductor at any accessible
    point from the load end of the overhead service conductors,
    service drop,
    underground service conductors, or service lateral
    to and including the terminal or bus to which the
    grounded service conductor is connected at the service disconnecting
    means. A grounding connection shall not be made
    to any grounded circuit conductor on the load side of the service
    disconnecting means, except as provided in Section
    E3607.3.2. [250.24(A)(1) and (A)(5)]
  10. jar546
    6,047
    316
    No, no it can't. We are talking at the point of the service connection either in the meter base or service disconnect.
  11. ICE
    ICE Sawhorse
    7,812
    728
    This cabinet appears to be intended for a bottom feed....but it’s not. Are the feed through lugs original equipment?
    #11 ICE, Feb 11, 2019 at 8:33 PM
  12. jar546
    6,047
    316
    I don't understand the question. You can see the meter section of this combo pack from above and the feeder leaving the bottom of the panel.
  13. ICE
    ICE Sawhorse
    7,812
    728
    There’s a tunnel on the left side. And the lugs?
  14. jar546
    6,047
    316
    Yes, it goes under the border fence.
  15. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,070
    750
    Jeff...Are we talking about the same thing? 250.24(A)1 allows the GEC to attach "before the main"...Correct? As well as the section from the IRC I posted...? In which case you would not see it in the panel.....? See exhibit 250.8 in 2017 handbook...
Share This Page
