    Dismiss Notice
    Dismiss Notice
Repair of Chair Lift
Discussion in 'Existing Buildings Codes' started by Tami Kump, Oct 24, 2018.
  1. Tami Kump
    Tami Kump Registered User
    Oct 24, 2018
    7
    0
    I have a turn of the century building (not sure if it's on the National Historic Registry) that had a chair lift added in the 90's. The lift is in the main entrance foyer and ascends 5 steps into the main portion of the office building. The building has since changed ownership and the chair lift recently became inoperable. My question is if the new owner is required to fix / replace the chair lift, or if it can be removed under the conditions of the Existing Building Code (which would not have required it to be installed in the first place).
    Any direction on this issue would be helpful and if you could also direct me to where I might find documentation supporting the requirements, it would be greatly appreciated!
    Thank you
  2. JCraver
    JCraver Sawhorse
    Feb 20, 2014
    554
    192
    Not really enough info. - a few questions:
    What kind of building/what use?
    How big is it?
    What's the occupant load?
    Is there an accessible entrance/exit somewhere in the building that's not associated with this lift?
  3. Tami Kump
    Oct 24, 2018
    7
    0
    Thanks for the quick response.
    It's a 4 story building used as office space. There are no other accessible entrances. The first floor is about 4,000 SF. My thought is that because the lift was already there, you can't make it less accessible than what it is now.
  4. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    3,113
    415
    It depends if it was required when the lift was installed (i.e. alterations, change of occupancy, etc.) not when the building was first occupied. Assuming the chair lift was provided for accessibility in Wisconsin currently under the 2015 Existing Building Code;
    410.2 Maintenance of facilities. A facility that is constructed or altered to be accessible shall be maintained accessible during occupancy.
  5. Tami Kump
    Oct 24, 2018
    7
    0
    PERFECT! That is exactly what I need Francis.
    Thanks so much!
  6. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,492
    117
    Nothing in the code about chair lifts. A chair lift cannot be a component of an accessible path so I would not think it would need to be replaced. I think the 20% rule might need to be used if there is work that requires a permit for this existing building.
    I do ICC codes. But I don't do ADA. What do you think ADAguy? An elevator for every to floor?
  7. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,623
    227
    Consider that the lift may have been seen as an alternate method/means.
  8. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,903
    700
    I thought of the exact section FV posted.....
  9. VillageInspector
    VillageInspector Sawhorse
    Feb 9, 2010
    65
    11
    I;m not sure how quick I would be to make a structure less accessible
Share This Page
