    Dismiss Notice
    Dismiss Notice
Polyethylene pipe tubing and fittings (PE)
Discussion in 'Fuel Gas Codes' started by linnrg, Apr 24, 2019.
  1. linnrg
    linnrg Sawhorse
    Mar 17, 2015
    344
    90
    This material is approved for use for natural gas in both the UPC and the IFGC.
    Are any of you seeing this being installed on the interior gas piping? Are there any requirements to observe or inspect the heat fusion.
  2. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,856
    359
    I believe GasCo using it to supply homes in the utility but haven't seen it inside. I see CSST yellow and black jacket being used inside.
  3. cda
    cda Sawhorse
    Oct 19, 2009
    15,845
    976
    Not my area
    Question
    Does it have to be
    Listed for underground use?
    Listed for above ground use?????!
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,364
    836
    I thought it was only allowed underground....Steel risers coming up.....Used it for my garage feed
  5. linnrg
    linnrg Sawhorse
    Mar 17, 2015
    344
    90
    I too have only seen it underground
  6. linnrg
    linnrg Sawhorse
    Mar 17, 2015
    344
    90
    found it
    UPC 1210.7 "... outdoors, underground only"
    IFGC 404.15.1 "... outdoors underground only."
    I think the guy that told me they were using it indoors back in the midwest must have confused it with coated CSST
Share This Page
