    Dismiss Notice
    Dismiss Notice
outdoor covered equipment platform-construction type
Discussion in 'Architects & Engineers' started by lmspringwater, Oct 25, 2018.
  1. lmspringwater
    lmspringwater Registered User
    Oct 25, 2018
    1
    0
    Hi, all
    I am currently working on a project, where the client wants to build a covered equipment platform attached to a existing type 1B building on second floor for loading/unloading and pass through. The structure is a two-story high outdoor space with covered canopy and partially enclosed sheet metal sidings on 3 sides. square footage wise it is about 1000 SF. My question is -- Since the existing building is type 1B construction, does this covered platform has to be treated as type 1B construction? (given the total metal siding area is over 25% of the structure's perimeter). Any inputs are highly appreciated!
  2. jar546
    jar546 *****istrator
    5,858
    283
    Hello and welcome. I am very confident that within the next few hours and days you will get a lot of feedback on this subject.
    Can I ask your involvement in this project so we have a better idea in what context this post is? We have code officials, inspectors, plan reviewers, architects, engineers and others in this forum that are always willing to help. Thank you!
  3. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,492
    117
    Need to know what codes are used there and occupancy use, sprinklered, size and height of the existing building. The existing building plus the addition must meet the allowed sq. ft. and height for the construction type of the addition unless there is a fire rated wall between. It also could make the means of egress longer.
  4. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,623
    227
  5. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,903
    700
    Devil is in the details on this one.....If it truly is an equipment platform, and not sheltering a use and really not part of the building, it might fly. Not part of the "primary frame"...Can you attach a drawing, picture, or sketch?
    Support and access elements for a piece of equipment in a building would not have to meet 1B requirements, so outside is feasible if you can convince the AHJ
  6. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,623
    227
    Is this use in a yard or on a roof?
Share This Page
