    Dismiss Notice
    Dismiss Notice
Multi-Purpose Room In Arena
Discussion in 'Canada' started by Joe Dogone, Apr 4, 2019.
  1. Joe Dogone
    Joe Dogone Registered User
    Apr 4, 2019
    6
    0
    This is for Ontario.
    Does a Multipurpose Room in an Arena need to be classified as an A2 occupancy and thereby requiring a 1HR FRR Separation from the rest of the A3 Arena?
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,287
    825
    Mixed use non-separated......
  3. Joe Dogone
    Apr 4, 2019
    6
    0
    Thanks.
    what is your OBC reference?
  4. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
    Some of us do not have access to OBC
  5. Joe Dogone
    Apr 4, 2019
    6
    0
    then how do I describe this to a Plans Examiner?
    I need to justify the position some how
  6. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
    Welcome
    Did not see you were new to this lovely internet stop
  7. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,797
    342
    Wheres Waldo, I mean tmurray, he's got an OBC I bet?
  8. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
    Do you have a copy of OBC??
    Are you designing the building ?
  9. Joe Dogone
    Apr 4, 2019
    6
    0
  10. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
    A little more than describing
    Plan design and notations more than likely
    Plus cost estimates
  11. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
  12. Joe Dogone
    Apr 4, 2019
    6
    0
    Can anyone provide Ontario Building Code references to support a no fire separation position?
  13. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,287
    825
    You will def have to wait for Tmurray, but id it mirrors IBC at all it should be in Ch5...
  14. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
    If some how you can post either the chapter on separation or a link to the entire OBC,
  15. Joe Dogone
    Apr 4, 2019
    6
    0
  16. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,287
    825
    Major occupancy means the principal occupancy for which a building or part of a building is used or intended to be used, and is deemed to include the subsidiary occupancies that are an integral part of the principal occupancy. The major occupancyclassifications used in this Code are as follows:
  17. cda
    cda Sawhorse
    Oct 19, 2009
    15,608
    950
  18. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,534
    385
    Sorry folks. I was away at a conference last week.
    It depends if the A2 is a subsidiary use to the A3. See the definition for major occupancy.
    If you are looking at 3.2.2 building classification, You don't need to consider it if it is not more than 10% of the area of the Floor Area where it is located. See 3.2.2.8.
    However, if the area will be used by a different party, then it would need the separation.
    If they are running a hockey game in the arena and someone else is having meetings in the multi-use space, they should be considered as two different suites and have the separation.
    steveray likes this.
  19. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,534
    385
    It takes some time to get familiar with.
Share This Page
