    Dismiss Notice
    Dismiss Notice
Is a Fire Pump Room a Wet Location?
Discussion in 'Electrical Codes' started by jar546, Dec 20, 2018.
  1. jar546
    jar546 *****istrator
    5,960
    296
    Do any of you, in your right mind, consider a fire-pump room to be a wet location because it has a lot of water pipes?
    Do you? What would be the reasoning if you do?
  2. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    cannot speak to electrical question,
    But normally there is water on the floor from something associated with the pump set up
  3. Msradell
    Msradell Sawhorse
    Jul 23, 2011
    781
    67
    No it's not a wet location anymore than the area in the residential basement where you have hot water heaters etc. is a wet area. Just because there are a lot of pipes giving moderate doesn't make it a wet area.
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    729
    Absolutely not unless there is some sort of required maintenance/ flushing that soaks the room, but I have not seen THAT fire pump yet....
  5. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Is there a definition for
    Wet location
  6. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,589
    277
    I would not consider a Fire Pump Room a wet location, hopefully there's a floor drain if used for other appliances like a WH.
  7. north star
    north star Sawhorse
    Oct 19, 2009
    3,620
    213
    Electrically speaking, ...Yes !..........From the NEC:
    Location, Wet: "Installations underground or in concrete slabs or masonry in
    direct contact with the earth; in locations subject to saturation with water or
    other liquids, such as vehicle washing areas; and in unprotected locations
    exposed to weather".
    cda likes this.
  8. jar546
    5,960
    296
    The only time a fire-pump room gets wet is if there is a failure of a component. I do not agree to call it a wet location. If that is the case then every room in a house or building that has plumbing is a wet location.
  9. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Ok per the definition not a wet location
    Just some of them not a nice place to be with the pump running, and you are the one who has to trust the electrical install
    When you decide to touch the controller and there is some water on the ground
  10. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    1,964
    255
    IT depends --- Had one fire pump that dumped cooling water onto the slab trench drain to filter and return to lake ----- So in short the splashing of the water into a badly designed trench drain system made almost everything wet about 30 minutes into the fire pump acceptance test.
    jar546 likes this.
  11. Gregg Harris
    Gregg Harris Saw Horse
    Jan 17, 2012
    898
    10
    Not a wet location by definition
Share This Page
