    Dismiss Notice
    Dismiss Notice
Gas boiler heating problem
Discussion in 'Plumbing Codes' started by William Clements, Oct 17, 2018.
  1. William Clements
    William Clements Registered User
    Oct 17, 2018
    4
    1
    Heating is done by a gas boiler,(old but works well) and water is heated via an indirect coil in the cylinder with a thermostat on the exterior about 2/3 way up from the bottom. I can never seem to get the temperature of the hardware right, it is either far too hot or just warm enough, it is noticeable when the shower is in use, I have to turn the shower control way down or full up.
    My first thought was the cylinder stat, so I replaced it, but no difference.
    The issue happens in the summer as well when the central heating is off, and the boiler is only in use for hot water supply.
    Obviously, when it is too hot I am wasting gas, not good. Need suggestions on this or else should I call plumbing repair service?
  2. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    1,006
    133
    I'm afraid it's the nature of the beast. A separate domestic water heater is your best bet.
    William Clements likes this.
  3. William Clements
    Oct 17, 2018
    4
    1
    Thanks
  4. HForester
    HForester Member
    Sep 21, 2015
    125
    39
    Run the thermostat higher than you need and put in a ASSE 1017 tempering valve to control (limit) the temperature to the hot water distribution system. This is the way it has been done ever since Holby valves came to be in 1930. I am not saying that Holby is the brand of valve you need to use but they were probably the first ones to design such valves (in the US). Many other brands are available.
    jwilly3879 likes this.
  5. jwilly3879
    jwilly3879 Sawhorse
    Apr 2, 2010
    157
    39
    This is also called a tempering valve.
    rogerpa likes this.
  6. HForester
    HForester Member
    Sep 21, 2015
    125
    39
    that's what i said: "a ASSE 1017 tempering valve" per IPC Section 613.1 (2012 edition)
  7. Master Pipe
    Master Pipe Registered User
    Dec 5, 2018
    4
    0
    You can see your gas boiler heating changed.
Share This Page
