    Dismiss Notice
    Dismiss Notice
Garage mandoor framing to code?
Discussion in 'Residential Structural Codes' started by Ammich1, Mar 26, 2019.
  1. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,797
    342
    What's on the other side of the door would help? If open to outside, distance to the main structure? Drywall may be needed on the wall, If opening into a basement, a door with a self-closing devise maybe required.
    As far as the hole, if the AHJ adopted the IPMC, see
    Section 304.5 Foundation walls , free from open cracks and breaks and shall prevent the entry of rodents and other pest.
    304.6
    Exterior walls shall be free from holes and maintained weatherproof.
  2. ICE
    ICE Sawhorse
    7,983
    799
    The gap at the bottom strike side can be filled with a piece of pressure treated lumber. The top needs a pair of full width horizontal 2"x4"s. I can't say for sure but there might not be an anchor bolt near the end of the bottom plate. I also don't see any toenails where I would expect them. The gap that tmurray spotted is a problem.....he has an eye for this stuff.
    Here in California there is no exposed Romex but you indicated that this is finished. What is the shiny surface attached to the ceiling. Is the ceiling flat or pitched?
    #22 ICE, Mar 27, 2019
  3. Ammich1
    Ammich1 Registered User
    Mar 26, 2019
    9
    0
  4. Ammich1
    Mar 26, 2019
    9
    0
    The ceiling is sheetrocked and the shiny things are brackets to the joists, if I am naming joist correctly.
  5. ICE
    ICE Sawhorse
    7,983
    799
    The drywall looks reflective in the picture. I can’t view the picture now unless I allow google access to my pictures...which I will not do.
  6. Bryant
    Bryant Registered User
    Dec 19, 2018
    12
    0
    looks like the RO was off the mark for that sized door. Appears missing anchor bolts on either side from what I can see. add that to the list of rejection items
Share This Page
