    Dismiss Notice
    Dismiss Notice
Fuel Gas Fireplace Bumpout
Discussion in 'Residential Energy Codes' started by Keystone, Dec 20, 2018.
  1. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    783
    95
    i am definitely the only one who is making this call, every contractor, framer and builder tells me so and if it's said enough times we believe it but really I think I am the only person making this call. I'm in zone 5, 90% of the bldr's use 2" by 6" exterior wall framing with R21 insulation, EXCEPT!!!! When it comes to the fireplace bump outs then for some unknown reason everyone thinks it's okay to use 2" by 4" with R13 or R15. This area is still part of the thermal envelope and is required to meet the energy code.
    I've been told;
    -that makes no sense.
    -you sure you want me to do that.
    -but I use that thermal ply stuff so that helps.
    -but I insulate the house walls to R21.
    -it's on my plans as 2" by 4". No no no it's not.
    -no other inspector even looks at that.
    Please tell me I'm not the only inspector looking at this or if I am then pass me a pink slip for being wrong or an award for being right!!!!
  2. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,924
    650
    I've been told;
    -that makes no sense. Yes it does when you read the code
    -you sure you want me to do that. Yes I surly do
    -but I use that thermal ply stuff so that helps. No it does not equal the minimum R- value required
    -but I insulate the house walls to R21. Not the walls around the fireplace bump out
    -no other inspector even looks at that. Really, well I will talk to them about what they have missed.
    JBI, my250r11 and Keystone like this.
  3. north star
    north star Sawhorse
    Oct 19, 2009
    3,620
    213
    O.K., ...you get an award for actually checking
    and knowing the applicable Codes........Also,
    for trying to obtain compliance to what has been
    adopted in your jurisdiction.
    Keep up the GREAT work ! ;)
    JBI and Ty J. like this.
  4. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    783
    95
    Hey all, I got an atta boy from North Star. Blessed be the season.
    JBI, Ty J. and jar546 like this.
  5. jar546
    jar546 *****istrator
    5,960
    296
    You are correct in your enforcement
    JBI likes this.
  6. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    729
    Suggest that they Rescheck it and if it passes they can keep doing it that way?
    JBI likes this.
  7. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    783
    95
    Yes I point that out for the ones that use ResCheck's but Pennsyltucky provides energy path options which are still clear cut but somehow I end up consistently writing this up.
    JBI likes this.
  8. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,542
    130
    I had this too for a whole development of cookie cutter houses and failed a framing inspection. Boss said to leave it alone if I want to keep my job.
  9. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,589
    277
    Keystone, do you get 2x6 framing for other bump-outs, like a kitchen window or bay wall?
    I agree with you it should meet the required R-value for your area.
    JBI and Keystone like this.
  10. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    783
    95
    I can go along to get along for a "transition period", allow time for existing houses underway but moving forward ground up homes properly built.
  11. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    783
    95
    That is the fun part, yes all other areas are 2 by 6 even dormer walls.
    JBI likes this.
Share This Page
