    Dismiss Notice
    Dismiss Notice
Fire place "cavity"
Discussion in 'Canada' started by go5, Jan 10, 2018.
  1. go5
    go5 Registered User
    Jan 10, 2018
    8
    0
    Hi all,
    Behind my natural gas fireplace there is a cavity (that is a build out of the back of the house). It is brick exterior but plywood with SOME insulation on the inside. The op of the cavity is a slopped roof. I am getting a bad draft from the top due to a soffit on the outside that is allowing the air in. After I removed the fireplace there was insulation above the fire place with a vapour barrier. I have removed both just to get up into the cavity.
    My question is can I make a more solid separation from the top of the cavity? run some 2 x 4's and add insulation and then maybe drywall? Is there a need for this cavity to have direct access to behind the fireplace?
    Thanks for any help
  2. cda
    cda Sawhorse
    Oct 19, 2009
    15,676
    957
    My guess is for clearance to combustibles, from the fireplace
    Sheet rock sounds great to me Type X
    Not a building code expert just makes since
  3. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    374
    165
    Can frame across to create a horizontal barrier. Use of OSB or sheetrock should be fine but not necessary if an air-barrier is installed properly. Make sure to consult the listing for the FP insert for minimum clearance to combustibles. Most inserts will have standoffs that establish the minimum clearances.
    Insulate the walls and lid with fiberglass insulation (rockwool is better for flame resistance) and use a fire-resistant air-barrier (like FSK).
  4. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    374
    165
    As an additional thought, make absolute sure that the space behind the FP is not an air plenum for combustion air. The FP (if a direct vent type, most are) will have an exhaust flue and a fresh air supply. These may be a pipe-in-pipe type. See the listing (installation manual) to verify.
  5. go5
    go5 Registered User
    Jan 10, 2018
    8
    0
    Thanks for the replies. It is a direct vent FP and has a pipe-in -pipe vent that goes direct outside. So I assume the air is not for combustion air
  6. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    3,113
    416
    Correct, it may be for ventilation to remove possible moisture. example;
    To eliminate the required ventilation install the minimum R-value of impermeable (rigid or spray foam insulation) below the roof deck and include the additional amount of insulation to meet the total R-value for your zone (see table below for amount of impermeable insulation for your climate zone).
    Example of zone 4 below;
    Additional resource on fireplace air barrier: Info-407: Air Barriers—Tub, Shower and Fireplace Enclosures
    my250r11 likes this.
  7. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,551
    390
    Natural gas fireplace would not require make up air.
    Just make sure to check the clearance to combustibles for your fireplace.
  8. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    374
    165
    And where did you get this wonderful idea?
    Combustion - Definition - a high-temperature exothermic redox chemical reaction between a fuel and an oxidant, usually atmospheric oxygen, that produces oxidized, often gaseous products, in a mixture termed as smoke.
    Regardless what type of fuel is burned, it needs oxygen (air), which should be supplied from an approved source.
  9. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,551
    390
    Sorry, I will correct my previous statement. A gas fireplace (natural gas, propane) does not have a need for passive make up air , which is what was suggested.
  10. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,977
    649
    Just remember Gypsum wallboard is not a "non-Combustible", It is a "limited combustible" and does need clearances.....
  11. go5
    go5 Registered User
    Jan 10, 2018
    8
    0
    thanks for all the replies all.
Share This Page
