    Dismiss Notice
    Dismiss Notice
Exhaust Flue Piping
Discussion in 'Fuel Gas Codes' started by north star, Apr 10, 2019.
  1. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    I have some existing, natural gas, Forced Air [ Heating ] Units
    that are being replaced with Infrared heaters........The FAU's
    have exhaust flues that penetrate the roofing assembly.
    A Contractor is proposing to remove the FAU's & install rain caps
    on the exhaust pipes, and leave it like that.
    QUESTION: Is there a Code section that "requires" the exhaust
    piping to be removed when the appliances themselves are
    removed ?..........We are using the `15 IFGC & the other `15
    I-Codes.
    Thanks ya`ll ! :cool:
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,287
    825
    Energy code for building envelope would be where I would look...
    C402.5 Air leakage—thermal envelope (Mandatory). The
    thermal envelope of buildings shall comply with Sections
    C402.5.1 through C402.5.8, or the building thermal envelope
    shall be tested in accordance with ASTM E 779 at a pressure
    differential of 0.3 inch water gauge (75 Pa) or an equivalent
    method approved by the code official and deemed to comply
    with the provisions of this section when the tested air leakage
    rate of the building thermal envelope is not greater than 0.40
    cfm/ft2 (0.2 L/s · m2). Where compliance is based on such
    testing, the building shall also comply with Sections
    C402.5.5, C402.5.6 and C402.5.7.
    C402.5.1 Air barriers. A continuous air barrier shall be
    provided throughout the building thermal envelope. The
    air barriers shall be permitted to be located on the inside or
    outside of the building envelope, located within the assemblies
    composing the envelope, or any combination thereof.
    The air barrier shall comply with Sections C402.5.1.1 and
    C402.5.1.2.
    north star likes this.
  3. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    & 0 & 0 &
    Thank you **steveray** ! ;)
    & 0 & 0 &
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,287
    825
    If they "sealed it and stuffed it with insul, I would not be concerned....Maybe put a note on it on the roof side that says remove when reroofing?
  5. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    804
    103
    I would take issue with the exhaust flue piping remaining in place, cite IFGC 305.1. “equipment and appliances shall be installed as required by the terms of their approval, in accordance with the conditions of listing....”
    The flue is no longer serving an appliance as approved & intended, placing a cap or any other material not approved by the listing authority is a violation.
  6. north star
    north star Sawhorse
    Oct 19, 2009
    3,671
    226
    Thank you for the information **Keystone** ! ;)
  7. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    1,050
    149
    They should be removed so somebody in the future can't hook up an appliance without noticing that the vent is capped and suffocating everybody in the building.
  8. Flexo
    Flexo Registered User
    Jan 28, 2018
    29
    3
    This reminds me of an incident I had about 20 years ago. I reroofed a home and with the owners consent, removed the protruding portion of a dilapidated, unlined brick chimney that was a vestige from when kitchens had wood fired cookstoves. Later the owner informed me that the gas company would not turn the gas on due to the water heater being vented into the now roofed over chimney.
Share This Page
