    Dismiss Notice
    Dismiss Notice
Electrical ICC Residential exam
Discussion in 'Electrical Codes' started by joetheinspector, Dec 6, 2018.
  1. joetheinspector
    joetheinspector Sawhorse
    Jan 1, 2010
    149
    2
    Any tips on preparing for the Residential Electrical ICC Exam?
  2. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    189
    88
    Speed tabs for the IRC.
    Other than that, read through it several times and learn the basic calculations. The Res exam was fairly mild; the Commercial on the other hand is a beast.
  3. SealPup
    SealPup Registered User
    Jan 21, 2018
    4
    0
    Is the NEC useful for this test at all?
  4. jar546
    jar546 *****istrator
    5,858
    283
    Yes, it absolutely is. I took the commercial electrical test over 10 years ago and then about 7 years ago I took the IRC electrical just for fun to see what it was all about. My background is electrical btw. I believe that you really need to understand the NEC because the verbiage in the IRC electrical section is from the NEC. All of it is from the NEC so if you are familiar with both, you will do better.
  5. joetheinspector
    Jan 1, 2010
    149
    2
    Thank you for the information
  6. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    189
    88
    Helpful, maybe if you already know the NEC like JAR does. If you are new to electrical, all answers for the Res Elec. can be found in the IRC, the NEC is not required. The IRC electrical section is fairly small, definitely a lot less than the NEC. Save yourself some effort, learn what you need and don't add an unnecessary book to the mix. Adding the NEC will only increase your chances of finding a similar but incorrect code reference.
Share This Page
