    Dismiss Notice
    Dismiss Notice
Definition of a Building
Discussion in 'Zoning' started by tomtomtom, Nov 5, 2018.
  1. tomtomtom
    tomtomtom Registered User
    Nov 5, 2018
    2
    0
    I am currently working with a client in a small town in Connecticut- I am dealing with an issue which defies legal precedent and industry standards:
    This is the Town's definition of a "building":
    "Structure of walls, post, columns or other devices which may or may not support a roof, and which is used for the housing, shelter, enclosure or support of persons, animals or property of any kind. Any other structure more than six (6) feet high shall be considered as a Building, including a solid fence or wall, but excluding an electric transmission line or an electric light, telephone or telegraph pole, radio or TV Antenna, highway bridge or flagpole."
    This town makes general references to "structures" however there is an absence of definition or specific regulations for what would conventionally be considered non-building structures- some of which are included in the definition of building: typically using language defining construction with a roof, used for shelter or dwelling.. a fence for example is by no normal criteria a building; nor a pergola which is the issue I am ultimately addressing with this zoning official who claims that a pergola is a building.
  2. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    729
    If a 6' high fence is a building or structure, then so is your pergola....They will win this one...Unless your pergola is 5'11"
  3. tomtomtom
    Nov 5, 2018
    2
    0
    I'll consult my land-use attorney: by no other legal definition is a fence a building- this is poorly authored code.
  4. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Welcome
  5. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Plus you are looking at
    Zoning
    As in I don’t want your tower in my backyard
    Not building code
    JBI likes this.
  6. JCraver
    JCraver Sawhorse
    Feb 20, 2014
    561
    198
    It's a broad definition but I don't think it's that poorly written - it's clear enough that your pergola definitely fits their definition of "building". Whether the definition holds up in court is a whole other matter, and will depend primarily on how good your attorney is.
    It'd probably be cheaper/easier to get an item on the agenda for the next plan commission or zoning board meeting (whichever authors the definitions) and petition to change the code. If you have a good argument that the definition should be changed, and can get the board to agree with you, that'll certainly be cheaper/faster than going to court.
    JBI likes this.
  7. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    Just a little more expanded from IBC
    BUILDING. Any structure used or intended for supporting or sheltering any use or occupancy.
    JBI likes this.
  8. cda
    cda Sawhorse
    Oct 19, 2009
    15,164
    907
    AREA, BUILDING. The area included within surrounding exterior walls (or exterior walls and fire walls) exclusive of vent shafts and courts. Areas of the building not provided with surrounding walls shall be included in the building area if such areas are included within the horizontal projection of the roof or floor above
  9. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,589
    277
    I could see where you could tie a canvass or tarp to a fence and connect it to two or three poles and have a shelter. I've seen done in Anaheim, CA along the bike way.
    A pergola can eventually turn into a building just like the kids playhouse.
  10. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    729
    If we can require a building permit for a 6' or 7' fence, don't see why zoning couldn't or shouldn't have a concern as well...What is the issue with the regs you are having? Setbacks? Lot coverage?
    JBI likes this.
  11. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,654
    234
    A fence> 6' is a "structure" subject to wind load and if masonry must be seismicly resistent (footing, rebar).
    A structure by definition must be self supporting, how tall is your Pergola?
    Consider cell towers and windmills, also cooling towers
    JBI likes this.
  12. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,654
    234
    Building Definition (towns):
    Pergola:
    A pergola is an outdoor structure (therefore by "their" definition a building) consisting of columns that support a roofing or supporting grid of beams and rafters. ... ( it may be freestanding or constructed over sitting areas or walkways)
    In order to gain a better grasp of the definition for "pergola," it is helpful to compare and contrast it with other outdoor structures with which it is sometimes associated, including: Arbors. Gazebos. Trellises.
    Arbor:
    formed of horizontal framework/trelliswork supported on columns or posts, over which vines or other plants are trained.
    Its a "construction", period.
  13. VillageInspector
    VillageInspector Sawhorse
    Feb 9, 2010
    68
    13
    Under the townships language your pergola is a structure
  14. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,772
    272
    Since the OP is not providing much information I will guess that the 'client' built the pergola without a permit and is likely in violation of a zoning setback requirement. The 'client' now wants tomtomtom to argue that it is not a 'building' and therefore not subject to a 'building permit' requirement.
    If that is in fact pretty much what's happening I might suggest you assist your client through the permit process and if necessary the variance process. That will be far simpler, faster and less costly than trying to fight a losing battle.
  15. jwilly3879
    jwilly3879 Sawhorse
    Apr 2, 2010
    157
    39
    Or Zoning defines a pergola as a structure and requires a Building Permit if it is over 140 sf and is subject to Zoning setbacks regardless of the size.
Share This Page
