    Dismiss Notice
    Dismiss Notice
Current residential deck code
Discussion in 'Residential Building Codes' started by Pcinspector1, Dec 19, 2018.
  1. Robert
    Robert Sawhorse
    Jan 29, 2016
    169
    17
    How many of you are seeing Deck2Wall spacers? They eliminate flashing & hold the ledger off the building by 5/8" for air circulation. Any issues with these other then the penetrations needing to be caulked?
  2. khsmith55
    khsmith55 Bronze Member
    Oct 23, 2010
    117
    3
  3. khsmith55
    Oct 23, 2010
    117
    3
    Not familiar with Deck2Wall spacers but I have been using Simpson BP1 (think 3.5"x3.5"x 3/8" washer) spacers at each bolt between the ledger and siding for over 15 years with great results (idiot proof).
  4. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    728
    Bumping this.....Anyone requiring frost protection or at least a footing/slab/concrete landing at the bottom of deck stairs? I know it is in DCA 6 and could make it into code, I am just having a hard time with it as I have never seen it cause an issue....
  5. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    783
    95
    Speaking of bumping, I was asked to bump requesting a landing and I do agree about not hearing this being an issue.
  6. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    728
    If grade is decent I do not request a formal "landing".....
  7. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,589
    277
    Requiring the slab at the base of the stairs but no frost protection below it, if that's the Q.
    Will also allow paver's.
  8. Sifu
    Sifu Gold Member
    Sep 3, 2011
    1,081
    85
    What Steveray said.
  9. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,528
    441
    Ditto
  10. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    728
    We (CT) have amended the FP section:
    (Amd) R403.1.4.1 Frost protection. Except where otherwise protected from frost, foundation
    walls, piers and other permanent supports of buildings and structures shall be protected from frost
    by one or more of the following methods:
    1. Extended below the frost line specified in Table R301.2.(1).
    2. Constructed in accordance with Section R403.3.
    3. Constructed in accordance with ASCE 32.
    4. Erected on solid rock.
    1. Protection of freestanding accessory structures with an area of 600 square feet (56 m2) or
    less, of light-frame construction, with an eave height of 10 feet (3048 mm) or less shall not
    be required.
    2. Protection of freestanding accessory structures with an area of 400 square feet (37 m2) or
    less, of other than light-frame construction, with an eave height of 10 feet (3048 mm) or
    less shall not be required.
    3. Decks not supported by a dwelling need not be provided with footings that extend below
    the frost line.
    4. The footing for the grade level termination of stairs or ramps attached to decks or landings,
    whether the deck or landing is supported by a dwelling or not, shall only be required to be
    placed at least 12 inches (305 mm) below the undisturbed ground surface in accordance
    with R403.1.4.
    Footings shall not bear on frozen soil unless the frozen condition is permanent.
    Which is just some really weird language IMO....
  11. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    728
    f. Cantilevered spans not exceeding the nominal depth of the joist are permitted.
    I have always used the balcony cantilever chart, but now that we have the specific deck joist chart, can we not allow any cantilevers greater than the depth of the joist for decks?
  12. Ty J.
    Ty J. Sawhorse
    Aug 2, 2017
    219
    103
    R507.5 - ... Deck joists shall be permitted to cantilever not greater than one-forth of the actual adjacent span.
  13. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,994
    728
    Code provisions that conflict....Say it ain't so....
    Update: there was errata here (that I just found) and I guess what it is trying to say is that you can use the joist spacing for no cantilever for a cantilever up to the depth of the joist. More than that you use the other table (up to the 1/4)
    #33 steveray, Jan 8, 2019
  14. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,411
    333
    You mean not everyone uses old hockey pucks?
    steveray likes this.
  15. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,411
    333
    We have never required it here and I have not heard of any issues.
  16. Pcinspector1
    Oct 28, 2009
    2,589
    277
    IRC 2015, R507.5 Adjacent span...So a 14-ft FJ span รท 4 = 3.5-ft.
    We have a maximum cantilever of 3-ft as a general rule, looks like I'll have to look at this again.
    Is there no blocking between the cantilever required anymore?
  17. Pcinspector1
    Oct 28, 2009
    2,589
    277
    Stack of washers maybe?
    Hockey pucks are made in Yugoslavia, can't afford the tariffs?:rolleyes:
  18. rogerpa
    rogerpa Silver Member
    Nov 5, 2009
    219
    40
Share This Page
