    Dismiss Notice
    Dismiss Notice
Combination Hi/Lo drinking fountain, one fixture or two?
Discussion in 'Plumbing Codes' started by Tim Mailloux, Mar 4, 2019.
  1. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,985
    267
    Interesting question, what does the plumbing code say as to how to test?
  2. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,985
    267
    Waiting for answers with baited breath, would the same be true when testing residential fixtures that all must be tested while running simultaneously?
  3. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,727
    169
    The code doesn't say anything about testing when anything else is running. But I never had to wait for anything to stop running to check the height of the stream for a drinking fountain yet. But I guess it could happen sometime, especially if the fire sprinklers are running.
  4. Mech
    Mech Sawhorse
    Oct 30, 2009
    741
    13
    Test the system how it was designed for "peak" flow (?).
    One method to determine peak flow is to use the Hunter tables / Hunter's method, which does not tabulate every fixture operating simultaneously. Dr. Roy Hunter's method assigns load factors to plumbing fixtures which are tabulated and then converted to a flow rate.
    If I know the sprinklers are running, I would not worry about getting a drink or flushing a toilet. I would be heading for an exit.;):);)
    my250r11 likes this.
  5. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,727
    169
    Can't find this by googling. If this is just math it won't help with measuring the height of the drinking fountain stream during an inspection.
  6. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,985
    267
    Ah, access rears its head with an unintended consequence?
  7. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,985
    267
    Good Stuff Mark, thank you
  8. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,727
    169
    None of this answers my question.
    If the water stream on a drinking fountain is not high enough to comply with code do I need to go around the building and shut off all plumbing fixtures that may be running and then check the drinking fountain stream height again?
Share This Page
