    Dismiss Notice
    Dismiss Notice
Can you do this?
Discussion in 'Electrical Codes' started by jar546, Mar 12, 2019.
  1. jar546
    jar546 *****istrator
    6,224
    369
    Here is a drawing submitted for approval. What is wrong with this? What information would you need to know in order to approve this permit?
  2. LCBob
    LCBob Registered User
    Dec 22, 2018
    18
    11
    More than one service disconnect is permitted, NEC 230.71; however an indoor and an outdoor service disconnect does not meet the grouping requirements of NEC 230.72.
    jar546 likes this.
  3. jar546
    6,224
    369
    Bingo! That is one of a few issues I sent back and the main issue too.
    Unless, of course he wants to feed the 60A from the interior panel through the meter base at which point we have another issue.....
  4. LCBob
    Dec 22, 2018
    18
    11
    Another issue...yes, as service conductors and feeders are not permitted in the same raceway.
    Also, I think a set of load calculations are in order as there may be over 100 amps of load being carried on service conductors rated at 100 amps.
    Joe Engel likes this.
  5. jar546
    6,224
    369
    Yes, yet another issue that they need to show
  6. chris kennedy
    chris kennedy Sawhorse
    Oct 24, 2009
    1,356
    106
    #4 good for 85A @ 75°C
  7. LCBob
    Dec 22, 2018
    18
    11
    Yes, #4 is good for 85 amps. But without knowing what the connected loads are, the conductors on the line side of the meter can exceed 120 amps and is not permitted.
  8. ICE
    ICE Sawhorse
    7,901
    774
    Is this residential or commercial? The 100 amp label on the meter cabinet stands for what exactly?
    #8 ICE, Mar 14, 2019
  9. jar546
    6,224
    369
    It is implying that the meter can is rated for 100A
  10. ICE
    ICE Sawhorse
    7,901
    774
    Residential?
  11. LCBob
    Dec 22, 2018
    18
    11
    I hope the answer is residential.
    I assumed it was residential.
    If not residential, my previous posts are embarrassing.
  12. jar546
    6,224
    369
    Residential, sorry for the delay.
  13. ICE
    ICE Sawhorse
    7,901
    774
    What is the ampere rating of the proposed service?
    #13 ICE, Mar 15, 2019
  14. ICE
    ICE Sawhorse
    7,901
    774
    This is a thread with a lot going on but it isn't getting enough attention.
    #14 ICE, Mar 16, 2019
    jar546 likes this.
  15. jar546
    6,224
    369
    Agree
  16. jar546
    6,224
    369
    I will have to assume 100A since the meter base is rated at 100A
  17. ICE
    ICE Sawhorse
    7,901
    774
    Alrighty then....in your best estimate, is 100 amps sufficient?
    Out of idle curiosity, do you normally receive such drawings for approval with residential services?
  18. jar546
    6,224
    369
    Most of the time we do but missing was the load calc for the dwelling, panel schedules and a drawing that had more detailed info.
  19. ICE
    ICE Sawhorse
    7,901
    774
    We never get drawings or load calcs. What we get is a permit for a 200 amp panel. Now and then there's a 400 amp panel. Upon site visit, an inspector might request load calcs.
    And that 100 amp service in your drawing.....is it too small based on the two main disconnects and that's why you want load calcs?
    Getting information out of you is not that easy. You can have a lawyer present during this questioning.
  20. jar546
    6,224
    369
    It is simple, we require it and we get it or no permit. The service has to be the right size and we want to make sure it is. It is not uncommon for the load calc to result in a service upgrade.
Share This Page
