    Dismiss Notice
    Dismiss Notice
Building Designer (Unlicensed) - "forum"
Discussion in 'Building Designers' started by RickAstoria, Oct 26, 2009.
  1. MyDream
    MyDream Registered User
    Jul 15, 2016
    15
    0
  2. MyDream
    Jul 15, 2016
    15
    0
    Can you give a reason why you feel this way I am looking for any weaknesses so I can work them out. Check lists are what every architect and building designer or any designer will use to get there floor plans right. They did in the last firm that I worked at. Without them you would have to memorize every thing that should go on a floorplan, what happens if the code changes and you aren't using code checklists you can miss a code.
    Below is the Florida law about building designers
    http://www.leg.state.fl.us/Statutes/index.cfm?App_mode=Display_Statute&Search_String=&URL=0400-0499/0481/Sections/0481.229.html
  3. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,411
    333
    Before being a building inspector I was a designer and operated as the owners representative and third party building code inspection for single family dwellings. I have never used a code checklist in design. The most important thing I've found is the ability to understand what your customer wants, not what they are telling you they want. Then good plans and specs and respect for trades to have a good working relationship with them. The whole thing is way more about people than it is about memorizing codes and standards.
  4. MyDream
    Jul 15, 2016
    15
    0
    The building code checklist is for making the building planning summary and all of the various information needed from the code book that must be present on the plans as well as construction instructions from the code book about masonry or stud walls also known as notes. Anyways, information on glazing, doors/windows, occupancy classification, etc must be presented on plans. If you use a guideline when preparing your plans it will help in making the review time shorter. Making the task of getting the building permit a breeze instead of expecting the structural engineer to do it. I want to be professional, I want to be a master, I want to be able to get an engineer to be impressed with my hard work and fine craftsmanship. I need that engineer to look at me and say this guy knows the codes has it on the plans effectively. Has details that can hold up to his scrutiny giving me his trust and guidance when needed.
    Getting the clients wants and needs are the apart of the program( qualitative and quantitative research specifically) in the pre-design phase before the actual design takes place and I have my ways of getting that from the client. As a designer you must be a liaison between the client and what they want, you must be a swifter that takes in the clients program and swift out a end product that will awe and amaze the client. You should be able to give 3d visuals of the design with animations that will shock and awe a client into falling in love with what he/she and the designer himself have worked so hard to create.
  5. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,772
    272
    "As a designer you must be a liaison between the client and what they want, you must be a swifter that takes in the clients program and swift out a end product that will awe and amaze the client. You should be able to give 3d visuals of the design with animations that will shock and awe a client into falling in love with what he/she and the designer himself have worked so hard to create.".
    Sounds like the TV show 'Property Brothers'. LOL
  6. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,411
    333
    By checklist are you talking about the construction notes that are physically on the plans or a checklist that is used internally for the design process only?
  7. MyDream
    Jul 15, 2016
    15
    0
    tmurray, there are a lot of different checklists that people use for different things. One architecture offices' list may be different from another's and serve different purposes. The list that I am referring to is a plan review check list that goes over what codes would be on a set of working drawings in order for it to pass review from the building department instead of relining on the engineer to do all the work, I want to have a level of professionalism that will greatly benefit my clients and my peers who work with me and around me. One note is: CONCRETE MASONRY UNITS (CMU) SHALL BE HOLLOW UNIT MASONRY IN ACCORDANCE WITH ASTM C-90 AND SHALL HAVE A MINIMUM F;M OF 1500 P.S.I. This is a typical note on a set of working drawing for a masonry wall. Note came from the
    FBC 2014
    SECTION 2103 MASONRY CONSTRUCTION MATERIALS
    2103.1 Concrete masonry units.
    My check list will make sure that I do not miss a note like this, which could make me seem like I don't know what the hell I'm doing.
  8. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,654
    234
    Much as it pains me, there is always room and possible success for those with talent, ambition, business sense and communication skills. You may be that person or not.
    Two of my former students are getting buy and putting out a professional appearing product. Have you considered aligning yourself with a design/build contractor?
    With the right GC it could be mutually lucrative and you might gain E&O protection.
  9. MyDream
    Jul 15, 2016
    15
    0
    I found out quite a few things sense the last time I have been on this forum especially when it comes to the codes. I have been thinking about working with builders a lot lately and I feel confident. Thanks for you response.
  10. MyDream
    Jul 15, 2016
    15
    0
    Also I am having a code of ethics problem for what ever engineer winds up stamping my working drawings "plan stamping". I am working on a solution to this problem and it seems like I made have found a solution:
    NSPE Code of Ethics for Engineers 2c-
    Engineers may accept assignments and assume responsibility for coordination of an entire project and sign and seal the engineering documents for the entire project, provided that each technical segment is signed and sealed only by the qualified engineers who prepared the segment.
    So, in order to protect my engineer and to protect myself I will complete the plans and specifications which is not illegal to be done by someone who is not an architect, and from there I will have an engineer review and make redlines on what needs to be changed and created a set of engineering drawings, which will be signed and sealed by the professional who will then be able to assume responsibility for coordination of the entire project, but only seal what he created and assume responsibility of the entire project. Only one problem do all the plans have to be sealed in order for them to receive permit?
  11. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,542
    130
    It always seemed to me that they use the code plan reviewer as a code check list.
  12. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,654
    234
    There continues to be much work for draftsman/designers doing small to medium sized homeowner projects.
    You indicate you have a degree (what subject ?)
    What CAD programs are you using: Sketchup, REVIT, ?
    Might also align yourself with a decorator, kitchen designer, etc. Contact local ASID chapters and put the word out.
    My 2 former students don't seem to have a problem getting work.
    I take it you are under 30? You have a big mountain to climb playing catchup as to code and product knowledge.
    Are you offerring: permitable, biddable or buildable drawings? Each requires more time and a higher level detail.
    Have you developed a standard services contract, based on what?
    Join CSI and take their CDT (Certified Document Tech) 10 week course, it will explain a lot.
    Become an AIA Associate member of your local chapter. Members are always looking for staff temps.
    Good Luck
Share This Page
