    Dismiss Notice
    Dismiss Notice
Builder's fix on BCI Joist cut
Discussion in 'Residential Structural Codes' started by RN1218, Dec 1, 2018.
  1. RN1218
    RN1218 Registered User
    Dec 1, 2018
    3
    0
    On a walk through of new home build before dry wall, our inspector found some serious cuts on Joists.
    One of them cut off the upper flange and web, and is under the bathroom with bathtub over it.
    Another one cut through the upper flange.
    Then the builder did a "fix" with several 2x6 nail into it vertically.
    I do not think those do any good. Any suggestion?
  2. RN1218
    Dec 1, 2018
    3
    0
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  3. ICE
    ICE Sawhorse
    7,693
    675
    Your picture links do not work
  4. RN1218
    Dec 1, 2018
    3
    0
    Here are the pictures:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. fatboy
    fatboy Administrator
    Oct 17, 2009
    5,501
    424
    Not acceptable..........require the stamped manufacturers engineers repairs in these areas, do not let them cover it. Is there a jurisdiction inspector? Have they been there?
    my250r11 and JBI like this.
  6. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,766
    272
    Engineered wood products NEED to be installed per manufacturers specifications and I don't believe any of those fixes are in the manufacturers builders guide (downloadable from the manufacturers website BTW).
    A licensed engineer could come up with a properly designed fix, but most will shrug and refer you to the manufacturer.
    The manufacturers have engineers on staff that usually go into the field and either recommend a fix or possibly require removal of the now damaged product.
    my250r11 likes this.
  7. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,623
    227
    Don't you just love Sawz-alls and apprentices?
    JBI likes this.
  8. jar546
    jar546 *****istrator
    5,858
    283
    I hope your Texas code inspector does their job for your benefit
  9. Keystone
    Keystone Sawhorse
    Feb 23, 2010
    768
    84
    Also put a level on that 3" drain, the picture certainly has the appearance that drain is without pitch.
    tmurray likes this.
  10. tmurray
    tmurray Sawhorse
    Jun 10, 2011
    1,397
    326
    We use almost all engineered floor joists here. In my experience, if the top cord of the joist is cut less than half through, the fix is usually a 8' 2x4 with 4 nails on either side of the cut. But the repair details do change from manufacturer to manufacturer, so always rely on their specific designs. We require the contractor to submit these whenever the joist is damaged.
    We have only had one house where the cuts were this bad and LVL were added on both sides of the joists for the full length of the joist. That plumber has never plumbed another house here.
    Pcinspector1 and JBI like this.
  11. Pcinspector1
    Pcinspector1 Platinum Member
    Oct 28, 2009
    2,533
    247
    I haven't seen blocking done that way except for squash blocks over a bearing I-beam
    Pic #1, need an engineered fix design for the flange and web cuts.
    Pic #4 need a horizontal steel strap were both top plates have been cut and I question the thickness of the wide metal strap covering the 3" pipe at the top plate on both sides?
  12. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,766
    272
    Half agree... plates needed to protect the pipe
    Half disagree... I'm not seeing this as a bearing wall, so the tie strap requirement of R602.6.1 may not be required.
  13. Pcinspector1
    Oct 28, 2009
    2,533
    247
    JBI, I think your right, it may not be a bearing wall, the wall above the floor is probably above the double I-joist in the photo. The T-wall intersection should hold it in place as well.
    The steel tie should be 16-ga with the proper amount of fasteners required. R602.6.1.
    JBI likes this.
Share This Page
