    Dismiss Notice
    Dismiss Notice
2015 IECC Section C505 Change of Use - energy requirements
Discussion in 'Commercial Energy Codes' started by George McGerd, Oct 25, 2018.
  1. George McGerd
    George McGerd Bronze Member
    Dec 19, 2013
    54
    4
    Paragraph C505.1 states " spaces undergoing a change in occupancy that would result in an increase in demand for either fossil fuel or electrical energy shall comply with this code." The next sentence talks about Lighting Power Allowances and references Table 405.4.2(1) and (2) regarding changes in occupancies.
    Has this paragraph ever been interpreted to also apply to building mechanical and HVAC systems? Or does it related to power and lighting requirements only?
    Thanks
  2. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,492
    117
    Anything that uses electricity or fossil fuel.
    George McGerd likes this.
  3. George McGerd
    Dec 19, 2013
    54
    4
    Following up on this. The way we understand this Section of the Code (C505) is that any change in occupancy or use of an existing building, which results in an increase in demand for either fossil fuel or electrical energy shall comply with this code. I pulled the commentary which goes on to say "the application of this section is straightforward..." Not so much in my opinion. I've received various interpretations on this paragraph. The prevailing one is that ANY change in occupancy (note, not necessarily a change in "use and occupancy") resulting in an increased energy use means we would need to address the energy use of that building or tenant area. In other words...if Bob's Hardware Store moves out and Jim's Hardware Store moves in, Jim now has to either A) bring the old existing building into full compliance with 2015 IECC using either the prescriptive compliance path or total building performance path -OR- B) add energy efficiency measures such that Jim's Hardware Store uses the same amount of energy or less than Bob's. Thoughts?
  4. JBI
    JBI Sawhorse
    Oct 17, 2009
    2,766
    272
    Read the definition of 'change of occupancy'.
    What you describe is a change of occupant, not occupancy.
  5. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,492
    117
    Only if they are doing work that requires a permit like adding light fixtures. And if they are they could replace the existing ones to low energy like LED's and not increase the energy usage.
    But if Bob's Hardware Store was not open sunday and Jim's Hardware Store is? Wouldn't that increase energy?
    I wouldn't go there.
  6. George McGerd
    Dec 19, 2013
    54
    4
    Thanks JBI. Rick - per what JBI is saying, a 'change of occupant' would not trigger the provisions of C505.1, since it's not a 'change in occupancy' as defined in Chapter 2 of IBC.
    JBI likes this.
  7. steveray
    steveray Sawhorse
    Nov 25, 2009
    5,903
    700
    Correct....And hardware store to hardware store should not increase energy usage.....When they try to jam the small restaurant into the old mercantile space in the strip-mall. it is problematic at best....Reinsulate the BUILDING change the windows, HVAC and all of the light fixtures and controls.....Small tenant COU killer
    JBI likes this.
Share This Page
